by 17northwood1
My harrier phone will not turn off
Re: My harrier phone will not turn off
Try holding down the volume up and power button for 10 seconds and your device should reset. You should then be able to turn it off.
Good morning @17northwood1
Thanks for stopping by community Smiley Happy
Did you manage to fix the problem you had?
It would be great if you could please let @Northerner and myself know if the help worked?
Thank you
Richard
