Highlighted
My battery keep s9 drain
My battery is dead by end of day every day
Highlighted
Re: My battery keep s9 drain
@Jenn2712  have you reported this to Samsung as they give you the warranty on the device and if it needs replacing they will do.
Highlighted
Hi @Jenn2712
Depends on your usage and open apps. 1 day isn't extreme if you use your device.
Highlighted
Hi and welcome to the community, @Jenn2712 🙂
What do you generally use your phone for?
