Highlighted
by Investigator
My answer machine won't work. I've set it but it says I'm unavailable
I've set the answer machine up with a recorded message. But all it says every time a call goes to it is that the number is currently unavailable.
Highlighted
Re: My answer machine won't work. I've set it but it says I'm unavailable
Hi @DanAuckland1
Welcome to the community. 🙂
What happens when you text VM ON to 150?
Highlighted
by Investigator
Unfortunately Nothing as far as I can tell
Highlighted
by Investigator
Dan
Highlighted
Did you get a text message back from EE, @DanAuckland1?
