by Stevethebrickie Investigator
My Samsung s7 only rings once and then goes silent
This happens quite randomly,rings once,then silent call keeps coming in with no divert to voicemail  grrr
Re: My Samsung s7 only rings once and then goes silent
Does this happen when you are connected to EE network or when connected to EE VOWIFI service?
Thanks,
Hello there @Steventhebrickie
Is this the one area this happens in?
Does your voicemail work ok for you at other times?
Thanks, Leanne 🙂
Hi Leanne
Had one call last night with one ring,phoned caller back,and she said it was ringing but didn't go through to voicemail.
Get Outlook for Android
EE Employee
Hi @Stevethebrickie
Have you tried to back up your phone and perform a master reset to see if this assist?
Many thanks,
Lee
