by ajcbench Investigator
My Samsung S7 is sending text messages twice! Why?
I only found out when my wife became so frustrated that all my messages were coming through twice. I then found out it's happening all the time. Help!!
EE Employee
Solution
Re: My Samsung S7 is sending text messages twice! Why?
Hi @ajcbench and welcome to the community.
Please try one more thing if the suggestion by @chistery does not work.
On your phone and your wife's phone delete the conversation chain between you both.
Do then test messaging and let me know how you get on.
Many thanks,
Lee
7 REPLIES 7
by Ace Contributor
Are you running any type of anti virus or scanning app on the phone?
Does MyEE usage show one or two texts being sent - So is it one text which is received twice or two texts with the same contents, if that makes sense? It would show if it's your phone duplicating a text or of there's a problem elsewhere.
I think It's 360 Security I have installed.
by Ace Contributor
@ajcbench Can you disable it and see if it still happens?
EE Employee
Solution
Many thanks,
Lee
Thanks for your help. Problem sorted  😉
Was happening with my brother, as well, deleted both conversations and re-started phone. Seems to be sorted. Thank you for your help  😉
EE Employee
Hi @ajcbench
Thats brilliant 🙂
Glad you are now sorted.
Cheers
Lee
