by Desertflower Investigator
My Samsung J3 will not connect to my Virgin hub 3 any more?!
I have reset the hub to factory settings, and all other devices have connected.  I have checked all the phone settings using advice on various forums and the ee shop told me that i'd done everything possible and advised me to have the phone sent away for repair. Would it be advisable to reset my phone and try that first?
by Expert Contributor
Expert Contributor
Solution
Re: My Samsung J3 will not connect to my Virgin hub 3 any more?!
@Desertflower yes I would try hard reset of phone.... Make sure everything is backed up and you no all email address and passwords used on device.
6 REPLIES 6
Expert Contributor
Solution
Hello there @Desertflower
Thanks for coming here.
If you can try the reset as @Rogersdave771 has suggested.
Let us know how you get on after 🙂
Expert Contributor
@Desertflower did hard reset work?
Just done a factory reset and lo and behold I finally have wi fi. Thank you for your confirmation and making me do that rather than sending it off!
Thank you, yes I now have wi fi!
Great news @Desertflower
Glad this is all sorted for you 🙂
