by swanny06
My Samsung Galaxy s6 won't charge.
I have a Samsung Galaxy S6 Edge which has stopped charging when I plug it in I get the lightening strike over the battery on the black screen but it doesnt charge. I have done a soft reset, a hard reset, I've restored it to factory settings I have also tried numerous different plugs and leads and it is still not charging!? Any ideas? Thanks Kate
Re: My Samsung Galaxy s6 won't charge.
You are best off calling Samsung mobile support as you might need a new battery. If you are insured then you may want to contact them about repairs.
by Jrobin30
I had the same problem I took it to be repaired expecting a new battery but it just needed a new fast charger 😊
Thanks for helping @Jrobin30
Glad you got your problem sorted 🙂
