by Mike75 Investigator
My Nokia3 does not fully charge max i can get is 80% any help out there please
MyNokia 3 will not charge any more than 80any ideas pleae
Solution
Re: My Nokia3 does not fully charge max i can get is 80% any help out there ple
Hi @Mike75
Welcome to the community. 🙂
May be worth backing up your information first.
8 REPLIES 8
@Mike75  Hold down power and vol-up buttons until you enter Recovery.
Format cache partition.
Also allow the battery to run completely flat and allowing about 10 minutes before you put it on charge and then leave on charge for a few hours ( 3-4 hours )
Won't that give me a factory reset and loose all my data?
Get Outlook for Android
Thanks I'll  try that Mike
Solution
Hi @Mike75
Yeah as I thought losing my data , I'll try the battery one first ,I'm concerned the phone is only just 12 months old, and there is no redress from 're.
Successful  thanks let the battery go flat and it worked Now got full charging when it has done  3 hrs  great.
Great news @Mike75
Thanks for the update.
Did the flat battery go flat and it worked Now got full charging. Thanks Mike
