by Vixen75 Investigator
Moisture sign but phone not been wet?
9 REPLIES 9
Re: Moisture sign but phone not been wet?
Have you used it in a damp/humid environment? Gym? Steam?
Make sure your power connector is dry.
EE Employee
Hi and welcome to the community @Vixen75
Which moisture sign has been activated?
Does the above question apply to yourself?
Many thanks,
Lee
It's does apply to myself. It shows on the top navigation bar on the left as a tear drop type symbol. Contacted EE who have suggested taking it into a shop. It did go off for a day or two then returned. My phone has not been wetter or submerged.
Vicky
Sent from my Samsung Galaxy smartphone.
by Brilliant Contributor
Vicky
It doesn' matter if you got it wet or submerged.
It can go off in humidity.
Do you take your phone into the shower room when you have a shower or bath? This can trigger it.
Rain can if it drops on the right place.
EE Employee
Hi @Vixen
What I mean by the above question is have you been in any damp humid enviroments?
Many thanks,
Lee
Nope
Vicky
EE Employee
Hi @Vixen75
I would indeed pop to a store to have this looked into, we may need to send the phone away for you.
Many thanks,
Lee
Ok. Thank you 😊
by Expert Contributor
Expert Contributor
It may also be a small speck of something conductive caught in the charger port. The handset will detect the short circuit and give you the message.
You could try turning off the phone. Use a small clean and dry paintbrush to gently clean the port. Do not be tempted to blow into the port as you'll be blowing warm humid air into it.
PS You'd be amazed how often glitter etc can get into a phone.
