by Moonchild77
New Member
Moby upgrade.
Currently got Galaxy Ace and can upgrade - options?
Don't want a massive phone!
Solution
Re: Moby upgrade.
Hi @Moonchild
Thanks for coming here to community 🙂
@Northerner has given you some great information.
You may also want to check out the EE Upgrades: All you need to know about upgrading your phone with EE. post to support you further.
Hope you get a great phone and something you want.
If you need help setting it up, feel free to come back and see us for help.
Richard
Re: Moby upgrade.
Are you with EE, Tmobile or Orange?
You should take a look in the shop area but depending on your tariff you will likely need to pay more than you are paying now.
Thanks,
Solution
Re: Moby upgrade.
Hi @Moonchild
Richard
