by Edenrosenfield Investigator
Mobile data isn't allowing me to send texts on snapchat, please help
Hi, I have a Samsung galaxy s6 edge and my mobile data isn't allowing me to send messages on snapchat, however it works on Wi-Fi. If anyone has a solution, it would be much appreciated, thanks
13 REPLIES 13
Re: Mobile data isn't allowing me to send texts on snapchat, please help
Hello there @Edenrosenfield
Are you able to access other websites when using data?
Has this worked previously for you?
Thanks, Leanne 🙂
Yes i can, as far as i know, it's just snapchat that doesn't fully work.
Thanks @Edenrosenfield
If you log into your My EE account how much data is showing remaining?
Has this worked in the past for you?
Thanks, Leanne.
It says 471MB left
OK, thanks @Edenrosenfield.
Have you been able to do this on mobile data before?
Yes i have and about 3 months ago it stopped working
Thanks for confirming, @Edenrosenfield.
Could you please try deleting the app and re-downloading it?
No luck with that one
Thanks for trying that, @Edenrosenfield
I'm stumped.
Are you on an EE contract or pay as you go?
I'll find out if I'm on co tract or pay as you go
I am on pay as you go
Read more
Read more
Thanks for finding that out, @Edenrosenfield. 🙂
I recommend speaking to our technical support team.
They will be able to run through some more troubleshooting and try and get to the bottom of this problem for you.
Please come back and let us know how you get on.
Thanks.
Ok thankyou
