by Iza Investigator
Micro SD card not appearing on phone
I have a micro SD card, and have had it for a while, but when I insert it into my phone, nothing happens. No notification or any sign it is in the phone, it doesn't have the option to format or mount the card in storage settings either. I have tried to format it eith my PC but it register there either. Can I get this fixed myself or shall I go to an EE store?
Solution
Re: Micro SD card not appearing on phone
Hi @Iza
Can you try another SD card as it sounds like the one you have tried is dead.
6 REPLIES 6
Solution
Hi @Iza
Hi @Iza
I recommend following @Northerner's advice.
That way we will know whether it is a problem with the Micro SD card or with the phone reading it.
Look forward to hearing from you.
by Iza Investigator
Ok, thank you. Will I be able to get one at an EE store as I was planning to go to one or shall I order one off a site?
it's difficult to say what stock the EE store would have. If you're passing, pop in and they'll do their best to help you, @Iza.
You can see our current online range on our accessory shop.
@Iza
Get one from Amazon as they will be better value.
by Brilliant Contributor
@Iza, or get one from EBay, also good value, never had a problem when buying them from there.
