by FT1708 Investigator
Micro SD Card Problem
I Recently Brought An New Micro SD Card A Few Weeks Ago. Which Is 32GB It Is In My EE Harrier Mini Right Now. Does Anyone Know How To Set It As Its Standard Memory? Because I Got One Notification That I Cant Get Rid Of. It Says 'Storage Memory Running Out' If Anyone Finds An Answer Please Tell Me I Would Be Gratefully Appreciate It. Thank You. - FT1708 Smiley Happy
Solution
Re: Micro SD Card Problem
You cannot as Android will always use your phone memory for core installation of programs/firmware and downloads.  You can move apps individually to the memory card via apps manager via settings and phones/videos should also automatically save to the memory card when installed.
Your memory card will not replace your phone core storage option.
Solution
