by AlainG
New Member
Messaging issue
I cannot send messages any more. Can you share the number of the SMS center so I can cross check I have the right one. Thanks all for the help
Solution
Re: Messaging issue
Hi @AlainG
The number you need is +447958879879
Solution
Re: Messaging issue
Hi @AlainG
