by Del192 Investigator
Make ringing longer before it diverts to voicemail
8 REPLIES 8
Re: Make ringing longer before it diverts to voicemail
Hi thank you for replying but I already tried that and tried again after reading your email but all that happens is I get a sign come up saying
CONNECTION PROBLEM OR INVALID MMI CODE.
Do you have any other suggestions please . I was just thinking perhaps it's already set at maximum 30 seconds I'll try putting 25 seconds in
And see what happens
Many thanks
Del192
Sent from my Huawei Mobile
Still didn't up my seconds still on 20 it verified and everything but didn't work shame
Thk you
Done that and it says 0 seconds how do I raise it to let's say 20 please
Thks
Del 192
by Ace Contributor
Hi @Del192
Try dialling **61*07953222222*11*30# then press call if successful it will appear on your screen.
by Ace Contributor
@Del192  dial *#61# and press call it will tell you how many seconds it's set for.
Thank you it was very helpful but it did not resolve my problem I done as you said and it came back 0seconds how can I alter it to let's say 20seconds please
Drl192
Hi @Del192,
How long is your phone ringing before diverting to Voicemail at the moment?
by Profile closed
Not applicable
@Del192 I tried what @David said to do and it worked. I used cut and paste to call the
And it confirmed to have actioned.
Then I checked with the *#61# and it verified it to be on 30 seconds instead of the prior 20. Thanks, @David because this had been a minor annoyance that I, too, had. And thanks @Del192 for asking this question. I hope that you get it to 30 seconds, too.
