by Profile closed
Not applicable
Login
I'm having a problem loging out of the log-in to my account page. Once I login, the page won't let me log out. It could be sticking I guess. The Community login page works fine with no
problem there.
I'm using a PAYG phone.
Can anybody help please! ☺
by Profile closed
Not applicable
Solution
Re: Login
Hi, tom222, I did what you suggested with no luck but then removed the
sim-card while my mobile was switch on and the problem corrected itself!
Whoopeee thanks Tom ☺
13 REPLIES 13
by Profile closed
Not applicable
Re: Login
Hello @Profile closed sorry to hear you are having problems logging out of MYEE. Try clearing the cookies/history of your browser then closing it, EE-opening it and trying again. 🙂
by Profile closed
Not applicable
Re: Login
Thank you for your reply Tom222 will do as you suggested and see if that
works. ☺
by Profile closed
Not applicable
Re: Login
Thank you Tom222 i'll do as you suggested and see if that works out ok ☺
by Profile closed
Not applicable
Re: Login
You are welcome @Profile closed hopefully this is working again for you soon. Come back to the community anytime if there is anything else you would like to know. 🙂
by Profile closed
Not applicable
Solution
Re: Login
by Profile closed
Not applicable
Re: Login
Hello @Profile closed glad to hear it is now fixed for you, thank you for letting us know how you resolved it. 🙂
by Profile closed
Not applicable
Re: Login
You're welcome Tom222, maybe others with a similar problem would be better
removing the sim-card and re-inserting it to cure a sticky problem with
login issues.
Re: Login
Good afternoon @Profile closed
This is a great suggestion! Thanks for sharing your thoughts, here in the EE Community.
Because I loved the support you gave today, I’m going to private message you with an evoucher code for EE accessories store to spend as you wish.
Keep up the great work – it’s people like you who make this community a great place to be!
Thanks, Leanne!
by Profile closed
Not applicable
Re: Login
Hi. Leanne, nice to meet you!
Thank you for also reply to me over a small sticky problem☺ I will always
pass on any problem fixes I learn with pleasure.
Kind regards Robbie
Re: Login
Hi @Profile closed.
Lovely to meet you too 🙂
That is great 🙂 Hope to see you around in the future!
by Profile closed
Not applicable
Re: Login
 Hi, again Leanne the gift was very welcome and appreciated. Thank you ☺
Re: Login
Hi @Profile closed.
No problem at all was my pleasure 🙂
Enjoy the £20.00 🙂
by Profile closed
Not applicable
Re: Login
 I will Leanne ☺
No need to reply!
TTFN ☺
