by ThatManDan Contributor
Lg g6 Bluetooth issues
Hi
Is there a fix coming for the lg g6 Bluetooth failure?
There is a current issue where the G6 will not connect to any Bluetooth devices, do EE know of a fix or can I cancel my upgrade?
Dan
Re: Lg g6 Bluetooth issues
What will it not connect to as I have no issues connecting to my bose headphones, tablet, other phones, garmin smart watches etc... In fact it works better than my S7 Bluetooth.
Can you provide more info on the issue you are having.
