by 09jeald Contributor
LG G6 cat9 or cat 12?
As the title states, is the LG G6 cat9 or cat12?
Solution
Re: LG G6 cat9 or cat 12?
Hi @09jeald,
Yes, the G6 supports cat 12 LTE.
12 REPLIES 12
by Profile closed
Not applicable
Hello @09jeald the LG G6 supports cat12 but not cat9. :):
http://www.gsmarena.com/lg_g6-8466.php
That's not how lte cats work, if you support cat12 by default you also support cat9. I was hoping someone could give an official answer from EE, gsmarena isn't always correct as carrier variants are different.
EE Employee
Hi @09jeald and welcome to the Community.
I will certainly look into it for you.
Many thanks,
Lee
Yes it supports Cat. 12.
Source = LG G6 service menu.
@Northerner wrote:
That's great thanks, could you upload a link to a screenshot/picture?
@Northerner wrote:
Hi, sorry I was referring to LTE Cat rather than HSDPA Cat
Solution
Hi @09jeald,
@James_B wrote:
Hi @09jeald,
Thanks @James_B so this makes it the fastest device on your network.
Hi @09jeald,
Yes, it supports the fastest speeds (Currently Cat 9) on the UK's fastest network. (This is also dependant on which price plan you are using)
by GingerPrince
New Member
What CATs does EE currently have deployed?
My research seems to be:
CAT 3 = everywhere you can get 4G
CAT6 = almost everywhere
CAT7 = quite a bit
CAT9 = a few places
CAT12 = no idea but the new (July) 4GEE mifi box suggests it can connect in to CAT12 so I presume it has some coverage?
Hi @GingerPrince,
Welcome to the EE Community. Smiley Happy
We started upgrading sites to support CAT 12 last year.
Thanks for your question.
