by iosman123 Investigator
LG G5 charging failure?.
Hello,
I've had a LG G5 since October; all has been fine with it until today when it has stopped being chargeable (using a variety of cables and chargers) - all that happens is that the phone gets hot. Have restarted it a few times, turned off all connections etc - nothing helps. The phone has not been dropped, been washed, or in other way mistreated. Its now down to 2 % battery and is not going to much good for long.
I'll be going to the EE shop soon to raise the issue but worth letting others know of it in the meantime. As far as google etc tells me this is not a known issue.
thanks
iosman
Re: LG G5 charging failure?.
Hi @iosman123
That device still has a removable battery. Buy another battery from Amazon to see if that fixes your problem.
Hi @iosman123
Welcome to the community.
It may be worth speaking to our Tech Gurus. They'll be able to run through some troubleshooting with you and hopefully get to the bottom of the problem.
