by Expert Contributor
Expert Contributor
January security
What security patch are peoples galaxy 8plus running? Mine is running November.... It's February tomorrow! My S7 edge was running January update before I upgraded to 8plus. I would have thought EE would have issued at least December update for 8plus, seeing as it's the flagship phone at the moment..... Or are they just waiting on Oreo to release with next security patch?
7 REPLIES 7
EE Employee
Re: January security
Hi @Rogersdave771 and welcome back.
We at EE want to ensure that these updates are released to customers in a timely manner and that the customer experience is at an acceptable level.
Your device will alert you soon as an update is available.
Many thanks,
Lee
Expert Contributor
@Lee_H I fully understand the way roll outs work but I am just confused over the fact that a 2+ year old phone can have a newer security patch over a newer hand set.
The BTU S8+ is running 1 December security patch.
Thanks,
Expert Contributor
@Northerner BTU!?! What's BTU mean?
Its the generic UK Samsung firmware, so free from bloat you get with the carrier firmware.
Expert Contributor
@Northerner how do I go about getting BTU update?
by Brilliant Contributor
My S8+ on Oreo Beta is on January patch.
Oreo Beta has now finished so you'l be unable you get it.
