by BRH Investigator
Is the one plus 3t compatible with EE network
I'm looking to purchase a one plus 3t and was wondering if it is compatible with EE network
by Jamie__S13 Established Contributor
Re: Is the one plus 3t compatible with EE network
The one plus 3t has 4g connectivity so it IS supported and will be supported on the network for many years to come.  I see no reason for a phone not to be supported on the network unless it is deemed dangerous for use (For example, the Note 7 will be blacklisted soon, unless it hasn't been done already).
by Bosshogg Established Contributor
It will work.
Volte will work, but not voWifi.
EE still insist on having their draconion fw installed for this to be enabled.
OP3 / OP3t / S7 / S8 owner.
Electronic Engineer by day.
Geek by night.
