by Skilled Contributor
Skilled Contributor
Is the Galaxy Note 3 fully compatible with EE 4g
I have a EE 4g Max plan and would like to know if the Galaxy Note 3 is fully compatible with the EE 4g network as the performance even with a full signal doesn't appear any better than before
Solution
Re: Is the Galaxy Note 3 fully compatible with EE 4g
It will work on EE network but because it has the older radio you will struggle to get EE full network speeds.
Solution
