by Hettyhutchinson
Is it possible to turn VoLTE off?
 Hi there,
My phone updated itself today (I have a galaxy A3). Since then I have had VoLTE at the top of my screen by my 4G signal. I have googled it so think I know what it means. Any details would be fab. Also can I turn it off? If not will it cost me anything outside of my normal EE plan?
Scarlet
Solution
Re: Is it possible to turn VoLTE off?
Thanks for helping @winston.
Let us know if you need anything further @Hettyhuthinson 🙂
by Ace Contributor
VoLTE will not cost you extra, as long as you stay within your monthly voice minutes allowance.
It is just like 2G and 3G, VoLTE is the 4G equivalent for voice calls 🙂
W
Solution
