Highlighted
New Member
Is data roaming free in Mallorca Palma
Highlighted
by Profile closed
Not applicable
Re: Is data roaming free in Mallorca Palma
Hi, @Tash42 Yes. Mallorca is part of Spain. It is an island off the east coast of Spain. So, yes, you can roam there and use your minutes, texts and data like you do in the UK. There are privisos though. For example, even if your monthly data allowance in the UK was 60 Gb, you may only use up to 15 Gb in any month period while abroad.
Highlighted
@Tash42   Text ROAMING to 150 to make sure roaming is enabled on your account, you can do this now if you wish.  Also login to your online EE account and make sure call abroad and premium rate numbers is enabled.   With this enabled you’ll be able to call back to the UK.   If your a PAYG customer you don’t need to do this as it’s already enabled.
Highlighted
Welcome to the community, @Tash42
I see you've been given a couple of brilliant bits of information here already.
Find out more information about what to do before you travel abroad >
All that's left is for me to say: have a brilliant time. 😄
