by AHC
Is WiFi calling available on LG G6?
I have an LG G6 as part of  EE contract and was wondering if it is possible to get wifi calling on the device as I am aware it is available on other high end devices.
In the call settinga there is no option for wifi calling.
Solution
Re: Is WiFi calling available on LG G6?
Did you get the phone from EE direct?
As per EE wifi calling help pages:
It's only available on the EE version of all other compatible Android and Windows devices which can only be bought directly from us in one of our stores, online or through our telesales team. At present, other Android and Windows devices bought from other retailers will not be able to support WiFi Calling.
Thanks,
13 REPLIES 13
Solution
Thanks,
by AHC
Yes I bought the phine direct. I did not buy it separately unlocked
Hi @AHC
Welcome to the EE Community 🙂
@Northerner is correct, we do offer WiFi calling on LG G6 devices purchased directly from EE.
WiFi Calling is simple to set up.
Simply connect your phone to WiFi, ensure you have the latest software installed and switch WiFi Calling on in your settings:-
From the home screen, tap the Apps icon >>> Scroll to and tap Settings >>> Under the Networks tab, scroll to and tap Call >>> Tap the WiFi Calling switch to enable it.
You should then be sent a confirmation text to say that it has been activated.
Let me know how you get on with that. 🙂
by brooky Contributor
This is so confusing. My friend bought an iPhone from Apple with a SIM only plan with EE and WiFi calling works.
Does it vary per phone? Can some phones still be purchased from a 3rd party and get WiFi calling and not others?
I just tested my wifes LG G6 with a PAYG sim from EE and WiFi calling doesn't show on the list.
Maybe someone can let us know which phones need to be purchased via EE and which phones don't need to be.
Hi @brooky,
Welcome back to the EE Community.
Yes, it varies from phone to phone.
The LG G6 must be purchased direct from EE to be compatible with EE WiFi calling.
Please take a look at EE WiFi calling: All you need to know for more information.
Hope this helps.
Does an iPhone need to be?
Hi @brooky,
No, all iPhones support EE WiFi calling.
by Brilliant Contributor
@brooky
No all iPhones are compatible.
This is because Apple doesn't allow networks to alter the firmware so all iPhones have the same version.
Great I see. Ok last question I promise. Would a Google Pixle 2 bought from a 3rd party work?
I ask about these three because;
1. My fiend has an iPhone that works with EE WifiCalling bought from Apple.
2. My wife has an LG G6 bought from Amazon (this won't work with WiFi calling by the sounds of it).
3. I am about to get a Pixel 2.
Yes the Pixel 2 will work from the 3rd party.
Won't receive 4G calling though.
Thank you!
@brooky  You say you tested with a payg sim,  payg customers don’t get this service it’s only full contract or sim only customers.
Please have a look at THIS
Perfect. Thank you.
