Highlighted
Is Huawei mate 20 pro dual sim?
Hello,
I'm interested in buying a black Huawei mate 20 pro in a monthly contract, but I need to know whether it is the single sim or the dual sim model LYA-L29
Also does it come unlocked? Since my second SIM is not from EE.
Highlighted
Solution
Re: Is Huawei mate 20 pro dual sim?
Hi @angelojo94.
Welcome to the community.
The version that EE are supporting for the Mate20 Pro is not dual SIM.
We do have some other dual SIM phones available in our online shop.
Jon
Highlighted
by Investigator
I think most phones now come unlocked. To all networks.
I believe the Huawei Mate 20 Pro is a dual sim phone. But there are two versions of it! (Dual Sim and Single Sim/SD card. You will have to review the model number the cross-reference if it is a dual sim version!
Highlighted
Thanks, do you know how can I check the model number on the EE website? I cannot find it.
Highlighted
Solution
Hi @angelojo94.
Jon
