by dennisnyadore1
Internet connection is slow
Help am using s7
Solution
Re: Internet connection is slow
Hi there @dennisnyadore1
Is this happening in all areas?
Do any problems show on the network status checker?
Thanks, Leanne.
Solution
Thanks, Leanne.
by dennisnyadore1
Problem solved called help desk and they fixed the problem asap
Great news @dennisnyadore1
Thanks for the update. Smiley Happy
