by Maryam27 Investigator
International calls barred please help ASAP!!
Hi, all my international calls (from UK) are barred? When I tried to unbar it - it says I need a password?? Where do I get this from?
Any help ASAP would be much appreciated!
Solution
Re: International calls barred please help ASAP!!
@Maryam27  Is your My EE app up to date if it is you can do this there.  Turn on there.
8 REPLIES 8
You need this activated on your account. You can call CS tomorrow after 8am,  and they can sort this out.
Solution
@Chris_B
I see these changes, didn't know about these!
On Android it's under add ons and you can activate this service.
Thanks, I have had a look on the app and got the add on to call abroad, so will hopefully be ok by tomorrow!
Thank you so much for your help!
@Maryam27  Your looking for something like this to turn on
Hi @Maryam27
Thanks for coming here 🙂
Has the information and help you've been given from @Chris_B and @Northerner helped you?
Thank you
Richard
Hi @Richard_C
Unfortunatley it hasn't worked for me, I enabled as an add-on.
I will call CS later on.
Thanks,
No problem @Maryam27
Thanks for the update.
Richard
