by MMobeen Investigator
International Calls Barred
I am pay monthly EE customer, Im currently in Dublin and my outgoing calls are barred.  I have tried to enter my pin to remove the bar, My pin is not being recognised and I cant even call customer services for help.
EE Employee
Re: International Calls Barred
Hi @MMobeen and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
I tried that Im still not having any luck
EE Employee
Hi @MMobeen
Are you able to recieve calls/texts?
Many thanks,
Lee
Yes Im able to recieve calls.  I recieve my messages and emails over wifi.
Thanks @MMobeen
I have sent you a private message to get some details from you.
Hope to hear back from you soon 🙂
