by Scottyw87
New Member
I want to turn my contents lock off
Can u help me please I want to turn my contents lock off
Solution
Re: I want to turn my contents lock off
Hi @Scottyw87
Try logging into your MyEE app then - Settings - Content Lock - change this to off. Then restart your device.
It should now work.
Thanks,
Solution
Hi @Scottyw87
It should now work.
Thanks,
