by Estebanez
I want to connect laptop to Sony xz1. Where is the network security key?
I want to connect laptop to Sony xz1. Where can I find the network security key?
by Ace Contributor
Re: I want to connect laptop to Sony xz1. Where is the network security key?
HI @Estebanez
As I understand you want to use your phone as WiFi hotspot.
Please go in your phone
Settings > Network & Internet > Hotspot & tethering.
Portable hotspot on settings > Configure hotspot.
Where you can see your hotspot name and password or you can use default password and network name.
For more details please fallow this link.
https://support.sonymobile.com/global-en/xperiaxz1/userguide/sharing-your-mobile-data-connection/
It's under your WiFi settings on your phone, it's the password /key. You can change or deactivated this but I would recommend against deactivating.
by Estebanez
That's brilliant thanks! Exactly what I am looking for.
EE Employee
Hi and welcome to the community @Estebanez
I'm glad you are now sorted.
Many thanks,
Lee
