by 64
New Member
I need my screen repaired
I have a cracked screen on my Huawei pro 20 that needs fixing
by Brilliant Contributor
Re: I need my screen repaired
You can end it off to EE who will repair it at a cost.
Or you can use one of the repair shops that are everywhere around the UK which might be cheaper but won't use official Huawei approved glass.
