by Julie251
I need help I cant text or ring coz it says not registered to network but I am
Re: I need help I cant text or ring coz it says not registered to network but I
Where are you? Have you tried switching it OFF then ON?
Hi there @Julie251
What device are you using?
Are you in the UK at the moment?
Also, are you with us on pay as you go or pay monthly?
by Julie251
It's ok now my partner fixed it the sim card wasnt sitting in the slot right but its working better now
Thanks for the update @Julie251
Glad you got it sorted. 🙂
