by Bettysdogs Investigator
I’m having problems with what’s app but only outside. Fine on the WiFi
Re: I’m having problems with what’s app but only outside. Fine on the WiFi
HiUsing Samsung S8plusSent from my Samsung Galaxy smartphone.
@Bettysdogs You have turned off content lock from your account?  You can do this from within your online account
Good Morning @Bettysdogs.
Welcome to the community.
In addition to @Chris_B's advice, is mobile data activated within your phone settings?
Does your data work for other apps?
Jon
Yes it does. I think it’s when I moved to EE. Was t mobile before.
Regards
Betty
Sent from my iPad
Hi @Bettysdogs.
In the settings on Whatsapp have you set downloads to WiFi and Cellular?
What phone are you using?
Jon
