by Debzhx
I'm abroad nd on a maxi plan but it's saying calls barred when I try make a call
I'm abroad nd on a maxi plan but my calls and texts aren't working! It's saying calls barred
6 REPLIES 6
Re: I'm abroad nd on a maxi plan but it's saying calls barred when I try make a
@Debzhx  Did you enable roaming on your account before you left the UK ?  Having a allowance to use abroad is not the same thing a roaming being enabled on your account and this still has to be done.
Hi @Debzhx
Are you able to text ROAM to 150?
Can you receive calls and texts ok?
Speak soon 🙂
by Debzhx
Hi no I'm not able to text, it won't send, it's strange as my data is working as normal
Hi @Debzhx,
There must be an international calling bar on your account.
Please login to My EE and wait for a pop up asking if you want to chat with customer service online.
A member of the team will be happy to help. Smiley Happy
by barbiesa Contributor
Wondering if that might be problem as well. I'm in the UK. My sister can text me from Germany, when I try to reply, it tells me I need to top-up my account (it's a new account that should have £20 credit on it).
Hi @barbiesa
I have been answering you here thank you.
Cheers
Richard
