by DeborahW Investigator
I have had my new phone and plan for 12 months and want to lower my monthly bill
Rubbish phone and high cost plan. Is there anything I can do to reduce my tarrif at least
6 REPLIES 6
by Profile closed
Not applicable
Re: I have had my new phone and plan for 12 months and want to lower my monthly
If you are on a 24 month plan, then no sorry, as you can't lower the cost of your price plan until your final month of your 24 month contract.
Hi there @DeborahW
Thanks for posting on the community.
Is your phone not working as it should?
What phone are you using?
Thanks, Leanne 🙂
Sony zx and it is constantly freezing. I am also a student and believe I can get student discount on my monthly tarrif but dont know how to get it added
by Brilliant Contributor
The discount can only be added at the begining of the contract or when you upgrade. It can't be added half way through a contract.
by Ace Contributor
Hi @DeborahW
Backup your phone to google drive and then repair your phone software via Sony Xperia Companion,
You can download on Mac or PC.
https://support.sonymobile.com/za/xperia-companion/#gref
I hope that can resolve your issue.
Thanks,
Hi @DeborahW
Thanks for coming back to us.
@BrendonH is correct this can only be added when you upgrade or take a new contract.
You can still get a 500MB data safety net, every month, to add this text STUDENT to 150 and follow the instructions.
If you can try @tahirmian advice for your phone and see if this helps 🙂
