by robtay6644
I have been waiting over 24hr for my phone to be activated what should I do next
by Brilliant Contributor
Re: I have been waiting over 24hr for my phone to be activated what should I do
I would contact EE and see what the hold up has been. But if you bought yesterday I wouldn't count weekend as a day so might work by morning.
Hi @robtay6644
Thanks for becoming one of the newest members in our community 🙂
Was the phone a new connection?
An Upgrade?
Or
Have you came across from another network?
@BrendonH is spot on, I would just like to also point you to have a look at our How to activate your new EE SIM Card post as well to see if you can get some support there.
It sounds a little obvious, but have you tried switching the phone off and on again to see if that gives it a prod to start?
Cheers
Richard
