by glenthorne
I have an s8 and want wifi calling but It's not an ee purchased phone
Hi all. I have an s8 plus. Purchased unlocked from outside UK. I want to have wifi calling, no options in settings. How do I get it ?
Re: I have an s8 and want wifi calling but It's not an ee purchased phone
If the phone is dual sim then you will not be able to have this function. If not then you will need to install BTU firmware which will may give you this option if Samsung have made it available.
Thanks,
by glenthorne
Ok. That explains that. I did get the dual sim model.  Thanks for your help
