by KaraH
New Member
I have an S8 and I am due to upgrade
I like the S10 and Note 9 (the note 10 is out of my price range) which is best or is there another phone I should look at.  I need a bigger screen than the S8 due to a disability I need it to have a good battery life in case of issues.
Thank you all in advance
by nopixel Contributor
Re: I have an S8 and I am due to upgrade
if it's size + battery life you're looking for I would say S10+ or Note 9, standard S10 is hardly any bigger than the S8. If you don't absolutely need the top processor maybe look at the A70 or A80 too, they'll be cheaper but bigger screens and lower res so the batteries should last a bit longer too.
Hi there @KaraH
Welcome to the community.
If you would like to know the specifications on the device you can view this on our EE Shop 🙂
It may be worth visiting an EE Store to view the devices and see what would be best for you, before placing your order.
If you order online or over the phone you do get 14 days to return the device.
Let us know what you go for 🙂
