by Coralb Investigator
I have a new Nokia 1 phone and can’t connect to WiFi
10 REPLIES 10
Re: I have a new Nokia 1 phone and can’t connect to WiFi
@Coralb    What Wi-Fi, your home Wi-Fi public Wi-Fi  down the pub WiFi.      Can you give more information please.
My broadband provider is SSE
Hi @Coralb
Have you entered the correct password when prompted. (It's normally case sensitive)
@Coralb   Are you putting the correct pass phase in to your device?  And do you have issue connecting to other WiFi signals ?
Hi,  I’m certain I’m putting in the right password but the reception signal on my phone is weak unless I go outside, then the wifi signal is weak.  Could this be the problem?
@Coralb   The cellular signal that shows on the device has nothing to do with the WiFi signal that shows on the device.  Not receiving a good WiFi signal outside is because your home is blocking the WiFi signal when your outside.
Are you able to connect to WiFi hotspots when out & about?
EE Community Team
Hi @Coralb,
Welcome to the community 🙂
Are you getting connected to the WiFi but then not getting a strong signal or can you not connect to your home WiFi at all?
Have you been able to connect a different phone or device to your home broadband OK ?
Alex 🙂
I cannot connect my phone to home wifi at all.  This is the first phone I’ve had that I would like to connect to wifi.  I don’t have a strong signal outside and no signal inside my home.
EE Community Team
@Coralb,
Can you connect any other devices to your home WiFi so we can check it is the new phone and not an issue with your broadband please.
Do you have a WiFi light that is on on the router itself?
You will struggle to get a WiFi signal outside your home. If you can be standing close to the router when your connecting then we will know if it wont connect at all, or if your WiFi signal is weak.
Alex 🙂
