Highlighted
by Valued Contributor
Valued Contributor
I have a Samsung J5 with 8 gig of internal storage.
Hi, can anyone help please.
My internal storage is almost used up with updates all the time, my question is if i use a much larger micro sd card (i only have a 2 gig one in my phone) am i able to load apps to it and would they work from the sd card so to save my internal storage?.
Thank you.
Highlighted
by Expert Contributor
Expert Contributor
Solution
Re: I have a Samsung J5 with 8 gig of internal storage.
@Grandad2 yes apps can be moved to sd card (some apps not all) do you know if photos and videos are saved to your sd card or internal memory?
8 REPLIES 8
Highlighted
Expert Contributor
Solution
Highlighted
Valued Contributor
Hi Rodgersdave77, Yes I do have photos and music on my internal memory and i think one or two small videos of our grandchildren.
As of now I have used 7.57 gig out 8 gig internal and 719MB used of 1.84 gig sd card.
Highlighted
Valued Contributor
My other question was, if I am able to transfer apps and my photos/music to the sd card and they work from there, will it be safe to delete stuff off my internal storage, I would not like to loose photos of our grandchildren etc.
Thanks.
Highlighted
Expert Contributor
@Grandad2 if you get a bigger sd card and then transfer apps/photos etc to sd card rather than copy to sd card then you won't lose anything and won't have to delete anything..... Do you have photos/videos backed up to Samsung cloud through your Samsung account?
Highlighted
Valued Contributor
Hi rogersdave77.
No I don't have anything backed up, I will look into this, it sounds like a good idea for extra storage. Would I have it as an app on my Phone or do I download off Google Play Store?.
thanks
Highlighted
Hi @Grandad2,
There's a huge range of option available in the Google Play Store. I personally use Google Photos.
Hope this helps.
Highlighted
Valued Contributor
Thank you James_B I will look at all the options.
Highlighted
No problem @Grandad2 Smiley Happy
