by jorgex18
I do not find firmware Kestrel EE g535
Good could indicate where I can download the firmware of the huawei G535 compilation G535-L11V100R001C440B123 is the last update of this equipment but I can not.
Greetings.
Re: I do not find firmware Kestrel EE g535
If the phone doesn't update when you check under settings, then it's running the most up-to-date firmware.
