by garry53
I cant block a nuisance call numbers on my phone can ee block them for me.
Can ee block a number that I can`t block on my phone?
Solution
Re: I cant block a nuisance call numbers on my phone can ee block them for me.
Hi @garry53
Could you try following the steps on the Samsung blocking calls help page?
Let me know how you get on.
Hi @garry53
No, EE cannot do that. Why can't you block it locally on your phone?
by garry53
Did try that but for some season it the only gives you the option to block on some numbers. I checked for a solution online and apparently some numbers can't be blocked only deleted. So I thought I would check with EE if they could do something.
The phone is a Samsung J6.
Solution
Hi @garry53
