by GillJames54
New Member
I cannot make phone calls it says network not found
My phone states no network found unable to make calls
by Profile closed
Not applicable
Re: I cannot make phone calls it says network not found
Hi, @GillJames54,
Not sure if this will help, but can You restart your device, please! 🤞🤗
Cheers
BustaCrabb
Hi @GillJames54
Thanks for posting on the community.
Are you in the UK at the moment?
If so, do we have any problems showing on the network status checker for the area?
Hope to hear back from you soon 🙂
