by RobbieA19
New Member
I cannot make or recieve calls on my Huawei Mate 20 Pro
by Ace Contributor
Re: I cannot make or recieve calls on my Huawei Mate 20 Pro
Hi, @RobbieA19 are you able to send or receive text, please?
please check your area network status http://ee.co.uk/ee-and-me/network/4gee/network-status-checker?intcam=ON_EE_NA_Community_toolkit_stat...
