by tnortham Established Contributor
I am outside the EU and I'm on pay as you go. I want to turn my voice mail off.
I am outside the EU and I'm on pay as you go. I want to turn my voice mail off. I typed VM OFF to 150 and I recieved a text message to tell me my response could not be recognised.
36 REPLIES 36
Re: I am outside the EU and I'm on pay as you go. I want to turn my voice mail o
Are you on EE, Orange or T-M?
EE
Try texting VOICEMAIL DIVERT OFF to 150, but I doubt it'll be any diff.
I typed it and sent it but there is no response to that text.
by Ace Contributor
Hello @tnortham you can turn voicemail on and off by calling 150 using options 2, 1, 1, 3. 🙂
tried that. I dont have enough credit to make the call.
by Ace Contributor
The only other way is through customer service using another phone:
http://ee.co.uk/help/get-in-touch
Or topping up then you will be able to via calling 150.
I stil have not found the answer to this question. I want to turn voice mail off by sending a text please as it will be cheaper.
Hi @tnortham
We usually recommend turning off voicemail before you travel (if you do not want it to be active).
Please see @tm90's post above.
Our customer service team will be able to help you.
Please contact them from an alternative phone.
I topped up my phone with £10.00. I rang the customer services. They answered. But I was cut off almost immediatley and sent a text to say that I now only had 75 pence worth of creidit. This is very poor customer service.
I have spent £10 and my voice mail is still not turned off.
by Ace Contributor
We do not have access to accounts to turn your voicemail off.
You will need to try the self serve options I mentioned above now that you can call 150 (options 2, 1, 1, 3) or try and connect to an agent again.
Is it critically imperative you turn voicemail off right now? Can you not wait until you are back in the UK?
I am not back in the UK for a few months. People are ringing me up and leaving voice mail and then getting anoyed that I dont get back to them.
I do not want to spend another £10 uncuccesfully.
The EE customer service isvery poor. I will need to reconsider who I go with when I get my next contact when I'm back in the UK
Hi @tnortham,
I'm sorry to hear you weren't able to get this sorted with customer services.
When you sent the VM OFF text did you have credit available on your account?
yes. I had credit on my account when I sent the VM OFF text. It still didnt work.
In fact I had £17 in credit on my phone.
Now I have 75 pence.
I think EE should do the right thing and reinburse me.
