by Hancor2 Investigator
Huawei p9. Screen won't lock during a call. Often find my ear has muted the call
Huawei P9 does not lock the screen when in a call so I often find my ear has put the call on hold or tried to transfer it. Has anyone had this issue and found a way to stop this happening?
EE Employee
Re: Huawei p9. Screen won't lock during a call. Often find my ear has muted the
Hi @Hancor2 and welcome to the community.
So I can try and assist, please may I know if you have performed a soft reset on the device.
Many thanks,
Lee
Hi, I don't think this an issue that any resets will solve. Since I have had the phone it has done this, it has also been off and on a few times. It seems the proximity sensor is always active, I have tried pressing the power button to lock the screen but the sensor overrides this. I also have looked for a setting but couldn't see anything obvious so was wondering if anyone else had the problem and found a solution.
Re: Huawei P9. Screen won't lock during a call. Often find my ear has muted the
Thanks @Hancor2
Do you have a screen lock active on the device at all?
Speak soon 🙂
