Highlighted
by Investigator
Huawei p40
When will be the huawei p40 series available on EE?
Highlighted
by Ace Contributor
Solution
Re: Huawei p40
EE haven't announced any plans yet to sell it, but I don't think in its present state it's ready for mainstream use anyway. There may be workarounds for some apps, but for most people, they won't be able to access any google apps, banking, bbc iplayer, Google Pay, etc.
It's a lot of money for a camera that can make phone calls!
7 REPLIES 7
Highlighted
by Ace Contributor
Solution
Re: Huawei p40
Highlighted
by Contributor
Re: Huawei p40
you can pre-order it from carphone warehouse, e2save and mobiles.co.uk. Fonehouse said they will also be stocking the p40 series. This is what i did as EE were unable to tell me any info.
Highlighted
by Investigator
Re: Huawei p40
I was searching high and low for deals - sadly, I couldn't find any what would suit the budget 😞
Highlighted
by Established Contributor
Re: Huawei p40
What's your maximum budget per month and what's your maximum up front cost?
Are you looking for the P40, P40 PRO or P40 PRO PLUS +?
Highlighted
Re: Huawei p40
Are you looking for the P40, P40 PRO or P40 PRO PLUS?
Highlighted
by Investigator
Re: Huawei p40
P40 pro
£110 upfront
£42/month 8gig data
Highlighted
Re: Huawei p40
Best deal i found:
www.three.co.uk/huawei/p40-pro/plans?bundle=Handset&colour=frost%20silver&memory=256
Its almost within your price and data range.
£99 upfront
£42/m
4GB Data
OR
£99 upfront
£45/m
12GB Data
