by tkulaga Investigator
Huawei p20 pro notifications
Hi
Does anyone know how to disable the annoying notifications that appear on the huawei p20 pro wheneve you close an app ."your phone is now in optimal condition" or " you have now freed up memory of blah blah blah"
and can you change the colour of the messaging app from blue?
thanks
11 REPLIES 11
Re: Huawei p20 pro notifications
Hi I emailed them last night, I will post their reply when I get it.
Hi @tkulaga,
Welcome to the EE Community.
Does this only happen with a particular app? Does it happen regularly? I've only noticed it a handful of times on my P20 Pro.
I've checked the settings in the messaging app and there doesn't appear to be an option to change the colour.
Hey
It seems to be every time I close apps down really annoying
Hi @tkulaga,
Can you please try updating your settings as below?
  • Settings
  • Battery
  • Tap the settings cog in the top right corner
  • Toggle 'Power-intensive prompt' off
Let me know if that improves things.
That still hasn't made a difference 😒
Hi @tkulaga,
Do you have any power saving modes enabled?
No my power saving is off
Hi @tkulaga,
I've looked into this for you and I haven't been able to find another setting related to these notifications.
Have you tried contacting Huawei support?
Huawei have advised there is no way of disabling them, so I suggested it be part of their updates.
So will have to put up with them annoyingly
Hi @tkulaga,
That's good to know, thanks for taking the time to update us. Smiley Happy
by Skilled Contributor
Skilled Contributor
the messaging app on the P20 Pro is the default Google Android Messages - you can change the colour based on the user - other solution would be to use a third party messaging app.
As for the notifications about free space I only get the small onscreen card at bottom of screen but nothing to say optimal
