by Onale101
New Member
Huawei mate 20 pro
I am looking to get this phone but does anyone know if it still uses google platform still with access to play store, google products etc, since the huawei issue? I dont want it if it doesnt have google products
Is it just the p30 and mate 30 that will be without Google?
Re: Huawei mate 20 pro
@Onale101  At present the device is still supported, but to be honest I wouldn’t as that could change with any new OS updates.  Perhaps @Northerner  can help more.
Hi @Onale101
At this moment in time yes. All current Google services are supported and likely will be supported in the future.
